A-Class (W177) (V177) 2018 to present
How To Guide - Engine Air Filter
Old Oct 2, 2023 | 02:19 PM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
This how to guide is for replacing the engine air filter in a 2019 Mercedes A220, this should be a similar process for all years with the 2.0 liter M260 Engine. This is an easy process and is recommended it be changed annually depending on your driving environment.
Part: Engine Air Filter
Mercedes Part# - A260 094 03 00
Hengst - HEN-E1621L
Mann - MAN-C28034
Step by Step Guide
Step 1 - Remove the ECU cover on the right side. This is done by simply pulling up on the cover. It is held in by 3 rubber grommets on 3 points (see image with the 3 locations in red)
Location of ECU cover
Pull up on the cover
Note the 3 grommet points
3 points the grommets attach to
Step 2 - Unclip the ECU, do not unplug the connectors. Then lift up from the back and pull back to free the ECU from the lip at the front. Then fold back and out of the way.
Unclip these 2 clips, 1 on each side
Then fold back and out of the way. Not the ECU has NOT been disconnected.
Step 3 - Remove cable clip on the right side, depress the tab and pull up and then set to the side.
Depress this (shown with pliers) cable clip to remove
Show with the cable clip removed
Step 4 - Unscrew the 4 - T25 screws for the top cover of the engine air filter housing. Note these screws do not come all the way out (prevents it from falling and getting lost) but ensure they are loosened all the way.
Location of 4 screws
Step 5 - On the air output tube to the engine, pull the clip out to loosen connection, this is needed for the next step.
Pull clip
Note the clip does not need to come all the way out, you will feels the resistance as if falls into an open state
Step 6 - Pull the top air filter cover up and then out from the output tube. Be gentle to avoid damaging the tube or gasket when removing. Remove your old air filter.
Top air filter cover off
Removed old air filter
New Air Filter (Left) vs Old Air Filter (Right)
Step 7 - Clean and vacuum out the air filter housing or any debris.
Cleaned out air filter housing
Cleaned the top cover off as well
Step 8 - Install new air filter and then reverse the process - Air filter cover re-install and screw in (Hand tight), re-engage the clip on the output tube, clip on the cable clip on the right side, secure the ECU back on top and clip into place, press on the ECU cover. Note on securing the ECU back in place, ensure the 2 tabs sit under the black plastic retaining pieces. See picture
Ensure the ECU tabs sit under the black plastic retaining pieces
Complete
