Classic Mercedes DIY tips and hints Discussion forum to share your DIY projects.
Injector tapping noise 603
Old Oct 15, 2024 | 02:35 AM
adler's Avatar
300sel- w109 .1971
The injectors on my 0m 603 engine make a very loud tapping noise that recedes at about 2500 rpm. One can easily mistake it for a rod bearing noise .
could it be air in pump or a pump issue? Lines are bled ,no air and equal drop in rpm while bleeding the injector pipes.
question is if they must be replaced , which make would be recommended .
Old Oct 15, 2024 | 11:48 AM
jimyj's Avatar
E320
Injector noise at lower RPMs, especially in diesel engines, might result from fuel coking on the nozzles or internal injector component wear, which alters spray patterns and can create louder inject sounds. Alternatively, worn injector return springs can result in improper seating, leading to noise that fades at higher RPMs as pressures peak and balance out. While less likely, issues with the injection pump or incorrect injector calibration could also contribute to these symptoms. Ensuring that the injectors are balanced and calibrated can sometimes mitigate these noises unless the wear is too significant, necessitating replacement.
