Classic Mercedes DIY tips and hints Discussion forum to share your DIY projects.
W124 300E 1990 passenger door hard to open FROM OUTSIDE
Old May 20, 2026 | 06:05 AM
high123bid's Avatar
01 S600
The door locks and unlocks fine. The door opens great from the inside. It requires a violent yank from the outside to get it to open. How do you lubricate or otherwise solve this, please?
Old May 21, 2026 | 04:47 AM
ygmn's Avatar
2015 E400 Sedan
check linkage from external handle to latch. might have issues.
Once door is unlatched should not matter if inside or out for force required.
Hence why I think it is external handle not unlatching it fully like only going to first latch and not opening up the second latch point all the way, so you have to pull door to get it to unlatch.
Old May 21, 2026 | 05:11 AM
high123bid's Avatar
01 S600
Thanks. What is the best way to access this? Door panel off?
Old Yesterday | 04:40 AM
ygmn's Avatar
2015 E400 Sedan
remove door panel.
Look around.
Might have to check actual handle itsel
