Carlsson Hood badge & MTX 2300X amp
09 ML350
I recieved a Carlsson hood badge for my car however it did not fit (well I did not like the way it looked). The badge was made for a 202 (C class) I dont konw if it will other modles but I know it does not look the best on the 124.
It is an orignal Carlsson part so it is of the highest quality. Make me an offer, possible trade for a different hood badge that will fit my car (94 E420, 124).
![](http://members.***.net/dcraigk/carlssonhood)
I also have an MTX 3200X amp. I just had it factory serviced about a month ago, so it is basicly a new amp (all the inner workings were replaced) I have all the paper work to prove the service as well. This is a top quality amp.
Here are the specs.....
2 channel
RCA input and out put
Gain control left and right
EQ control
Frequency control
Crossover (on off)
High Pass, Low Pass control
RMS Pwer measured at 12.5 Volts DC(car is off):
150 watts x 2 into a 2 Ohm load with than .05% Thd+N
300 watts x 2 into a 2 Ohm load with than .1% Thd+N
600 watts bridged into a 4 Ohm load with less then .1% Thn+N
Dynaminc Power (IHF-202 standard) Measured at 14.4 Volts DC (Car is running):
200 watts x 2 into a 4 Ohm load
375 watts x 2 into a 2 Ohm load
750 watts bridged into a 4 Ohm load
Signal to Noise Ratio: >110 db A-weighted
Damping Factor: >200
Frequency Response: 20Hz-20KHz
Thunder EQ: Variable Bass Boost (0-18db) centered at 40Hz
Crossover: Variable 50Hz to 200Hz, 18db/Octave, HP or LP configuration
Dimensions:
13" x 9" x 2"
14-1/4" x 9" x 2" (with mounting feet)
I had this amp on my 2 12" solo baric subs, I have since gotten an amp that more suits my style. So I am trying to get some of the money I spent on the amp back. Orignal price is around $600.
I would like about $250 for it.
If you would like more info or more pics of the amp let me know.
Thank you for looking
Subman
2 channel
EQ control
Frequency control
Crossover (on off)
Dimensions:
13" x 9" x 2"
Subman
