Zed built USX2100 amp and TC Sounds sub
Old Feb 27, 2008 | 03:25 PM
bumpnzx3's Avatar
W203 C230SS
Zed built USX2100
Underated specs:
100x2 @4ohms
150x2 @2ohms
300x1 @4ohms bridged
I bought this a while back when US Amps were made by Zed (anyone who knows car audio knows that Zed was a great build house). Amp is still new in the box, I never got around to using it. I did power it up last night just to be sure everything worked as it should. $100 shipped for the amp and a new KnuKonceptz 8ga install kit.
12" TC Sounds DB-500
400watts RMS/1000watts peak, 135oz magnet, 20mm Xmax, brushed aluminum cone......
This sub shares a lot with their TC-1000. I bought it a little while back when TC was clearing them out. It was mounted in an enclosure, last night, and used to test the above amp. Outside of that- it has no use. I never got around to using it. $100 shipped
I had plans to install both of these in my gf's car- but never did. I replaced the factory door speakers and that cured her desire for a sub. My ebay name is the same as my username here if you would like to check for references. I would guarantee this will out play (SPL and SQ) any combination you put together from your local stereo store or chain store for the price. I bought several of these amps and subs. 1 setup I used for my own use in my daily driver, and I used a few more of each in customer installs.
Old Feb 28, 2008 | 10:35 AM
bumpnzx3's Avatar
W203 C230SS
TC sub is sold.
Amp is still for sale.
