Need Fuse Chart - CLE450 Cab
I have a 2025 CLE450 Cabriolet and I'm trying to do a radar detector install; however, I have 2 problems.
1. I was going to do a 'mirror tap' and found out that you have to take off the front black plastic cover just forward of the mirror & you have to take down the control panel just behind it (has cameras, reading lights, etc.). I have not been able to get this off and I don't want to break it. I've found very little about this via online searches and YouTube videos. If you know how to do this and/or have pics and instructions I'll be grateful to have them.
2. Because of the problem above, I decided to do a hardwire installation, running the wires from the rearview mirror area down to the fuse block in kick panel in the passenger side floor well. Normally no problem, but I cannot find the fuse allocation chart. I've read that it's on the back side of the fuse block door but it's not on mine - just black plastic. I've also read that it's the underside of the door of the fuse block panel in the trunk, but there's no pic/diagram/legend there either. I've also read that there may be a folded up paper chart inside the fuse panels but, again, it's not on mine.
If I can ever figure this part out I'll use and add-a-fuse on a switched hot circuit and find a good ground and then run my wiring up and over.
MB must consider this to be top secret information since they make it so hard to get this information. I'm hoping that someone out there has this information and is willing to share it.
Again,
Thanks!
