Brake questions
1) Can i use porterfield pads on the front and keep OEM's on the back?
2) Is it true that Mercedes changes rotors as well as pads?
3) Can i use slotted rotors on just the front?
4) Anyone know some good slotted rotors that will work with stock calipers? (im not wanting to go for a big brake kit yet)
THanks
2. Yes it's true, but most of the time unnecessary.
3. Many cars that have slotted/drilled brakes are just in the front, the front does most of the work, so the back doesnt matter unless you want the look.
4. You can get brembo slot/cross drilled in o.e.m. sizes.
