H & R cupkit
clk
H & R cupkit
Can the guys/gals post pics of their 320s or 430s that are using H & R CupKit. I have a 320 with the same spring,pad, and shock setup as my buddy with a 430 and his car sits lower than mine.
clk
Ok....Is there a way to make my car lower besides using a cupkit? My setup is #2 pads in front #1 in rear H&R springs with bilstein sport shocks.
430 sits lower in the front because the H&R cup kit is designed for the 320 and the engine in the 430 is heavier. I have pad#4 up front and #3 in the rear. The rear still sits a little higher but i like it like that.
Heres a pic from the day I got it lowered:
http://www.mbnz.org/gallery/pics/122...00561102PM.jpg
It sits even lower now
W220, W208, W203
so you want the back lower? If you have 1 spring pad allready, your only option would be to cut a coil, sometimes it can affect the ride and sometimes it doesn't. I've previously done it on my brothers s500 and the ride did not change.
clk
I don't have the cupkit installed. I'm just wondering if the cupkit will lower my 320 more than my current setup.
W220, W208, W203
Yes the cupkit will probably lower your car about 1/2-1 inch lower than what it is now, i had the H&R's and Koni's then i got the cupkit and it lowered it about 1/2-1 inch more. If your looking for a cupkit, i'm selling mine.
I actually had more scraping/rubbing issues before I dropped the car. You have to think about how much stiffer the suspension is after you drop it. Your car doesnt dip as much. I have 19's on mine so it raises the car up off the ground a little. I put the stock rims and bumper back on today and it looks like its VERY low. 19's make my car so much slower. I only like them for looks.
W220, W208, W203
Here is my clk on the H&R Cup Kit. I'm running the stock pads, #4 in the front and #3 in the rear.
