How To Fix Squeaky Seats?
1. Squeaks coming from the side of the seat
Reason: the plastic side cover touches metallic seat frame
Solution: Removed the side cover, and bended those little plastic "teeth" that are in contact with the metal frame.
2. Squeaks from the seat meachanism
Reason: Metallic seat frame suspension elements, especially just below the front end of the seat, made sound when sat on the seat or moved on it.
Solution: Sprayed liquid oil on the moving parts (joints, etc.).
It helps if you have someone sitting on the seat while you are searching
the correct spots to oil.
I've enjoyed silent ride ever since, I hope it works for you too.
