Correct Tire Pressure for an 02 CLK 430
Old Jun 26, 2002 | 11:57 AM
chris7469's Avatar
1999 CLK 430
Question Correct Tire Pressure for an 02 CLK 430
I have been reading about all the different tire recommendations for the CLK. I just got an 02 CLK 430 and I have Mich. Pilot Sports. Can someone please recommend the correct tire pressure for the front and rear tires to ensure the best wear. My old 1999 CLK I went through 3 pairs of front tires with uneven wear and I drive normal most of the time.
Thanks.
CM
Old Jun 26, 2002 | 12:01 PM
BenzFAN's Avatar
2000, CLK430
What size?
Old Jun 26, 2002 | 02:14 PM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
Re: Correct Tire Pressure for an 02 CLK 430
Thanks.
CM
I use 37psi all around for the AMG staggered set.
Old Jun 27, 2002 | 08:21 AM
chris7469's Avatar
1999 CLK 430
I have the stock 430 17 inch AMG rims
Thanks. CM
Old Jun 27, 2002 | 08:47 PM
byip25's Avatar
2018 E400 COUPE SOLD -> Porsche Taycan 4S
look on your tires. it should have the recommend inflation.
B
Old Jun 27, 2002 | 11:00 PM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
Re: Re: Correct Tire Pressure for an 02 CLK 430
37/35 f/r
Old Jun 28, 2002 | 10:40 AM
CLK 320's Avatar
2001 CLK 320
Tires
Also, bear in mind that the inflation pressures on the inside of the fuel filler door are for cold tires. When at the gas station, I usually add about 4 psi to allow for the fact that the tires have warmed up. The next morning I go into the garage and set the pressures cold. Hence 36 psi on a warm tire usually winds up being about 32 psi the next morning when the tires have cooled down.
