HID...4300k or 6000K
2000 CLK 430
has anyone upgraded to 6000k? and if so....was there significant decrease in LUMEN/ Intensity of the light. Been looking thru the net and different chart have different LUMEN ratings for 6000k. Some say 3200 lumens...others say 2800 lumens? What are your experiences?
Thanks in advance
George
Thanks in advance
George
CLK430
I have 8000's in my CLK and they look great. 4300ks would be the same color as stock xenons. 6000's would be a little bluer, but not really. On warm days my 8000k's seem white to me. I would go for the 6000's. It would look nicer... I'll try to get pics of my 8000's when it gets a little darker out....
4300k Xenons will be the brightest as they are closest to actual daylight. Anything higher will look progressively bluer and then more purple but will not be as bright.
Sunlight has a color temp. of about 5200K, so a 5000K bulb would be the best chioce for brightness. The 6000K just looks better, you don't get that yellowish hue like the 4300K lights.
2000 CLK 430
hey josh, ghostrider, sicrx.....and anyone else....any experience with those OEM mccolloch bulbs on ebay? quality or crap?
CLK430
Ok... I took sum pics heres the 8000's I have installed.... I need to pet my side markers painted. The HID's look a little too blue in the pics. In person they are ALOT whiter with only a slight hint of blue. They are extremely bright, but don't project as far as the stock 4300k's on my escalade..
CLK430
2000 CLK 430
thanks everyone for their response....i just stuck with the stock ones...cuz they arent that bright to begin with anyways...and i dont wanna lose anymore lumens just for color
I have phillips 6000K on my car. As for brightness, it very bright, definitely, you'll see the road. Make sure you adjust your housing unit to shoot a little lower before people gets pissed and high beams you back on the opposing side of the street. As for color, it's basically white. At certain angles, you might see a slight hint of blue and velvet. But overall, it's white. It also depends on your housing unit though, it affects everything. I personally would've like to see more blue and velvet but didn't want to get in trouble with the law again. I got a fix it ticket once for having too much blue,velvet, and purple on my lights. That was the end of those lights.
2000 CLK 430
hey slvstar....lemme check out your lights soon...im local in alhambra and work in pasadena...so im not to far from arcadia.....we should all have a local mini meet? for all the sgv pple....josh, david, danny, me, you ????
What are the new S class using? It seems that everytime I see a 03-05 they are very purple. Is this because the bulbs are newer as opposed to say a 2001-2002 which has been used longer and changed color?
W208 55 & R170 230
4300k would be the brighest., the higher the color temp the lower the lumens output at the same rated wattage!
however 6k and 8k seems brigher because human eye precieve the blueish light better...
