oil change problem
Old Aug 10, 2005 | 10:35 PM
02mbclk430's Avatar
oil change problem
Hello All,
I just finished changing the oil in my 2002 clk430 and I didn't do enough research on the type and weight of oil that should be used. I used mobil 1 5w30 and read that it is not on the list of approved oil's. Do you think this is going to be a serious issue even though I change it every 5000 miles? Should I run out and get 0w40 as reccommended? And advise would be helpful.
Old Aug 10, 2005 | 10:57 PM
patrick39's Avatar
01' CLK 320
Originally Posted by 02mbclk430
Hello All,
I think it is better for you to follow the spec., if I were you, I would drain the 5W-30 and change it back to 0W-40.
0W-40 can go down to lower temp. than 5W-30 but now it is summer and I am not sure if the difference between the two is huge or not.
Old Aug 11, 2005 | 12:03 AM
midget fidger's Avatar
E550 Coupe
you can try calling up the dealer to see what they would put in it
Old Aug 11, 2005 | 01:18 AM
E55AMG99's Avatar
1951 Caterpiller D6
Don't bother with the dealer. They are clueless. The oils are vastly different in their makeup but under normal conditions they will both provide excellent service for your engine. Even though the 5w30 is not MB 229.3 or 229.5 certified, you should have no problem getting 5000 miles out of it. If you are curious, go to the dealer and look at the oil they put in. Most likely, it is Pennzoil or some other less expensive oil. Smythe and Beschoff in San Jose both use Pennzoil as their "house" brand. You have to ask for Mobil 1 and sometimes pay more for it.
http://www.mobil.com/USA-English/Lub...bil1_5W-30.asp
http://www.mobil.com/USA-English/Lub...bil1_0W-40.asp
Old Aug 11, 2005 | 04:57 AM
mtimmy's Avatar
W208 55 & R170 230
It dont' really matter.,
I put 5w30 in my supercharged clk55 ....
no problem at all.
Old Aug 11, 2005 | 07:34 AM
MeNmyCLK430's Avatar
CLK 430
Leave the oil in - it's fine. Just use 0W40 next time if you are really concerned about it.
Old Aug 17, 2005 | 12:01 PM
x15jq's Avatar
i am alsousing the 5w30 mobil one since it was onsale at costco 20 bucks for a 6 pack. No problems with it, i change it twice a year, usually about 7k per change.
Old Aug 17, 2005 | 12:24 PM
RobertG's Avatar
things with and without wheels
viscosity of oil in your engine depends on where you drive climate wise. If its hot go with 0w40 if it's cold like Canada go with 0w30
