W208 Offset
Old Aug 12, 2005 | 07:17 PM
Co 55 AMG's Avatar
W208
W208 Offset
Can someone tell me the correct offset for 18” wheels on 01’ CLK W208? I have been told et38 front and et38 rear. Can this be correct?
I’ve seen in sig’s here with many guys running 18’s and up. What is the recommended offset? Thanks.
Old Aug 12, 2005 | 09:30 PM
mtimmy's Avatar
W208 55 & R170 230
I am running 35.!!!!
Old Aug 12, 2005 | 09:31 PM
vraa's Avatar
What width 18's?
I'd probably run 18x8F 18x9R with 31mmF and 35mmR.
I've seen the same width rims run 30mm F and R though!
Old Aug 12, 2005 | 09:38 PM
LowRydeR's Avatar
From my past experience with 19s, I've done 32mm front 28mm rear, which was the most aggressive setup I've gone through, but 35mm front and rear is probably the recommended offset.
-Bruce
Old Aug 12, 2005 | 09:51 PM
mtimmy's Avatar
W208 55 & R170 230
I am running 19X8 front and 19X10 rear., with 235 front 265 rear.!
it really depends on your rim I have 3 inch lip in the rear.. ... and it cannot clear the brake caliper... I added 10mm spacers on each side., and make it flash with the fender., looks very nice.... so basically I am running
25 offset in the rear.
Old Aug 13, 2005 | 12:02 AM
Co 55 AMG's Avatar
W208
Originally Posted by ricky.agrawal
What width 18's?
18x8.5F with 225/40 and 18x9.5R with 265/35R.
thanks
Old Aug 13, 2005 | 12:06 AM
Co 55 AMG's Avatar
W208
-Bruce
Thanks Bruce, I like the look of your ride.Were did you get your rear deck spoiler?
Old Aug 13, 2005 | 12:08 AM
Co 55 AMG's Avatar
W208
Thanks, I would like to see pics rims, sounds bad a**!
Old Aug 13, 2005 | 12:09 AM
Co 55 AMG's Avatar
W208
Old Aug 13, 2005 | 01:59 AM
LowRydeR's Avatar
Yeah sure, the brushed aluminum finish set is the 32/28 setup, and the gunmetal finish set is 35/35.
-Bruce
Old Aug 13, 2005 | 02:28 AM
SAMSAM's Avatar
hi guys excuse me !!! can U please explain to me whats the offset and the spacer and thank you alottttttt
