Climate control can't be controlled!!
Old Sep 5, 2005 | 05:55 PM
seealkay's Avatar
this morning my climate control is like stuck or something and wouldn't turn off or change temperature, i pressed reset a couple times but no help. I left the car parked at my work place at 10, then came back at 2, it is still blowing air out of the vents even when the engine is off and everything. what should I do? what should I do other than disconnecting the battary which i've already done? thanks!!
Old Sep 5, 2005 | 06:10 PM
TresX's Avatar
For now....
Just pull the fuse that controls the blower. You most likely have a faulty blower motor regulator. (not the motor, obviously) Pretty simple DIY.
