HID lights
Old Sep 25, 2005 | 02:43 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
HID lights
Where can i get a set of these lights for a 99 CLK 430 and also the matching bulbs for the fog lights thanks in advance.
Old Sep 25, 2005 | 04:59 PM
midget fidger's Avatar
E550 Coupe
fog lights underneath or do you mean the little lights in between the main headlights? foglights might be kinda tough, but for the city lights it's easier (LEDs)
Old Sep 25, 2005 | 05:35 PM
sicrx65's Avatar
CLK430
I just pulled out my city bulbs. I think it looks 10 times better without them.
Old Sep 25, 2005 | 06:43 PM
TresX's Avatar
Get LED's....and it'll be 10 times better than that.
Old Sep 26, 2005 | 08:13 PM
acb3nz's Avatar
Im so confused
Old Sep 26, 2005 | 08:35 PM
TresX's Avatar
You have 2 options. Buy OEM Xenon Housings or buy an aftermarket ballast and H7 bulb. You will then install the ballast and bulb in your original housing. Obviously option 1 is the proper choice, but option 2 isn't too bad at all. It's what I did.
As far as matching the foglights, you can get the same aftermarket HID ballast but this time with a H3 bulb. This will be your best bet for matching the two.
The city lights, which are the two interior lights can be changed as well to LED's. This has proven to be the best possible choice.
Note: Using aftermarket HID ballasts, bulbs and LEDs will trigger the lamp out message. You will need 15-25 ohm load equilizers to get rid of this error.
If you go completely aftermarket, you could probably get the entire setup for about $450.
2 - HID kits
2 - LEDs
6 - load equilizers
Old Sep 27, 2005 | 11:18 AM
nmsno27's Avatar
I think going aftermarket on the HIDs is better than going OEM. This is obviously personal preference though. If you want to pay i think its like 1k for your lights you can. I went with 6000k which I think looks a lot better than OEM. Driving next to cars with stock xenon make them look like halogen next to me. As for LEDs, they match, I like them. I still have the fog problem and havent found anything to match. I was thinking about just getting yellow fogs instead. Will this look really bad??
Old Sep 27, 2005 | 12:21 PM
Josh K's Avatar
Tesla Model S
I had the same issue so I just went with yellow fogs on my car. I like the way it looks. I still prefer OEM xenons cause the actual housing looks so much better than the halogen one, and you can always put 6000k bulbs in the OEM housing. Sure it's considerably more $$$, but eh...
Old Sep 27, 2005 | 12:35 PM
M1M2M3's Avatar
Mercedes
Let me get this right you don't have any city lights. Do you get the malfunction?
Old Sep 27, 2005 | 12:38 PM
nmsno27's Avatar
Do you have any pics?
Old Sep 27, 2005 | 12:40 PM
M1M2M3's Avatar
Mercedes
the lens on my fog lights are all scratched up does anyone have the same prob.
Old Sep 27, 2005 | 03:09 PM
sicrx65's Avatar
CLK430
Yeah I do get the malfunction, but I already had a light malfuction on there because of my aftermarket HID's. But I still think it looks 10 times better with my inner lights even if they are led's. It just looks like too much is going on.
Old Sep 27, 2005 | 03:28 PM
TresX's Avatar
Why don't you get load equilizers to get rid of your Lamp Out Errors? Installation takes no more than 15 seconds for each light. (Just clip on) They cost $4 bucks each.
Old Sep 27, 2005 | 04:54 PM
blackbenzz's Avatar
haters crazy
I did the same thing as sic (I thought I was the only one). It looks good but the inner lights are very dim. Where do I get load equalizers from and how do I know which ones to get? Thanks.
Old Sep 27, 2005 | 04:58 PM
TresX's Avatar
http://autolumination.com/equalizers.htm
Scroll to the bottom of the page. You want the first ones ("15-25Ohm"). If you get LED's you'll need 4 in total. If you just want them for your aftermarket HID's you'll need 2.
Old Sep 27, 2005 | 05:40 PM
nmsno27's Avatar
why do you need 4 if you're getting these for your LEDs?
Old Sep 27, 2005 | 05:44 PM
TresX's Avatar
2 for the LEDs 2 for the HIDs = 4
Old Sep 27, 2005 | 06:24 PM
Josh K's Avatar
Tesla Model S
I'm gonna get my bumper repainted this week and then I'll take some pics :0)
Old Sep 27, 2005 | 07:51 PM
LorinserCLK430's Avatar
eh taking the bulbs out may get rid of the ugly lights but then you get the ugly "lamp defective" malfunction on the dash. i hate that.
anyway, i put those white h7 bulbs in the middle lights and the color is a lot better than oem. its nothing like upgrading to xenon but if you put a set of h7 in there, you know the superwhites that cost like $20-30 per set at any auto parts store, it will make some difference without actually hurting your pocket.
Old Sep 28, 2005 | 10:25 AM
nmsno27's Avatar
Cool man thanks
Old Oct 9, 2005 | 05:48 PM
acb3nz's Avatar
2 - HID kits
2 - LEDs
6 - load equilizers
Can you or some1 else give me the link for total aftermarket i have $450 dollars for the upgrade hook me up with the link, i will do the other way but im a little mechanic stupid so i prefer to do it the other way aftermarket
Old Oct 10, 2005 | 12:44 AM
TresX's Avatar
2 of theses (1-H7, 1-H3)
http://cgi.ebay.com/ebaymotors/H7-80...04791645QQrdZ1
and 2 bulbs (BA9 5LED's) and 2 load equillizers (15-25ohm) from :
http://autolumination.com/otherleds.htm
Good luck!
