Any sugestions for more HP on a 320?
Old Oct 5, 2005 | 12:56 AM
krayzie_e99's Avatar
2000 CLK 320
i have a stock 00 clk 320 and want to add more power to it. do any of yall have any suggestions?i heard of some kind of chip that will eliminate the stall when you press the accelerator. is there a supercharger for a 320? any help wud b appreciated,thanx
heres a link to one of them chips i mentioned.is gettin that a good idea??
http://www.eurorev.com/products/inde...roduct&id=3296
Old Oct 5, 2005 | 01:59 AM
King320's Avatar
03 C32 AMG
I'm not familiar with that chip company but to answer your questions...
1) yes there is a supercharger for the 320, kleeman makes it but its expensive.
2) you can look at evosport's underdrive pulleys, they will help with low end acceleration and throttle response. Also, you might look at getting some Green or K&N filters or making a custom cold air intake with some metal tubing and a mandrell bender. Exhaust adds a little power, but mostly sound. You can also look into more expensive options like headers or camshafts if you wanted to go that far. Check out evosport's website for some good ideas, but for the 320 you're going to have to be creative.
Old Oct 8, 2005 | 11:12 PM
midget fidger's Avatar
E550 Coupe
nah don't spend money on a chip. superchargers are pretty expensive (in the +$9,000 range). i dunno if trading it for a 430 is an option? cheaper than a supercharger
Old Nov 2, 2005 | 02:25 PM
King320's Avatar
03 C32 AMG
You might try to mimic this setup on the crossfire with green twister intake cones, but you'd have to fit an airbox from an SLK or Crossfire onto the CLK.
http://www.greenfilterusa.com/twister.asp
Evosport pulleys are a good idea
Other than that, you can do an eisenmann exhaust
http://www.eisenhaus.com/main.php
There was a guy on here a while ago doing a turbo CLK 320 but he hasnt been on in a while. If you want to get better performance out of the car though, you should definitely change the suspension, its doesnt make the car faster HP wise, but around the corners it will make more difference than any of the above modifications.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
