Smart Key
thanks
you actually don't need to have a battery in the key for it to work in the ignition... you just need battery to use the lock/unlock/trunk/panic function...
if the battery is dead, go replace the battery... its only about $2-3 from radio shack or Fry's
open the key up as if you were replacing the battery.... once you have that part out, you will see a very small black retaining clip holding the main board in place.. you can try and use a peperclip or a thin knife to push it a little and pull the main board out....
OR, you can just force it out and break that little black clip... it won't do no harm to have it broken. once that is done, pull the main board out and swap the cases and there you have it... a new outer shell for only about $20 from ebay...
