Help with a Nut and Bolt in the Front Wheel Arch?
Old Nov 2, 2005 | 02:49 AM
Benzino_CLK230's Avatar
CLK 230 Kompressor
Hi guys, There is a suspension arm thing in the front wheel arch where the wheel sits.. at the top of the tyre at the back there is an "Suspension arm" thing which has a Nut and bolt that hangs down.. How much clearance do you guys have between the tyre and the Nut?
The reason is that I have just put some Carlsson Rims on and the tyre is bloody close the this bolt.. Its not touching but its a few mm off and I am worried that if I go over alarge bump this may make it hit the tyre and cause a blow out.. Is this normal or am I just ebing paranoid?
Ill jack the car up tonite and take a pic so you know what I'm on about.. Any help would be greatly appreciated.. Thanks Guys!
Old Nov 2, 2005 | 04:37 PM
x15jq's Avatar
na it wont hit, i even grinded that nut down to fit some wider tires once. Thats your upper a arm and that bolt is for the upper ball joint, the tire will only get taller the faster you go, so you dont have to worry about rubbage.
Old Nov 2, 2005 | 06:45 PM
CLK 230 Kompressor
Pheeeww..Thanks Mate.. Much appreciated
