H&R Springs, Pads & Tire Size
Can anyone comment on this set-up and what the ride height might be? Should I get at #3 for the front and use the #2 in the rear? Will I need to purchase a camber kit or get different shocks (I believe the car has the AMG-Bilstein gas-pressurized shock absorbers) Where do you purchase a camber kit if it is needed? Does the camber kit only work in the front with no adjustment in the rear?
Finally, I would like to put 235/45/17 on the front (current wheel size 7.5Jx17 in) and 265/40/17 on the rear (current wheel size 8.5Jx17 in). Will this actually work without rolling the fenders and will the tires most likely rub? Thanks for your imput.
https://mbworld.org/forums/showthrea...euro+spec+w208
https://mbworld.org/forums/showthrea...ht=impressions
BTW, the fenders come rolled from the factory on your AMG.
Do you have the 17' wheels also? Do you still have the stock shocks? What size and brand of tires do you use? Thanks for your information.
Allan
Allan
