What tyre pressure?
Old 07-02-2003, 07:50 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Re: Thanks
Originally posted by SoCalCLK
The pics really help. I was sure you were referring to the 17" AMGs.
Comparing the even to the uneven is really helpful. So 36 Front and 37 Rears is good?
No prob, glad I could help... I think I'm running at 37-38 Front, 35-36 Rear.... The Front should have higher psi since the engine makes the front heavier...
Old 07-02-2003, 08:00 PM
mmgrad's Avatar
Re: Re: Thanks
oh yeah, if your tires are as bad as that in the picture, you can probably run the fronts at 38-39 so they can even out a little better (by technically overinflating it a little)
Old 07-06-2003, 02:09 PM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
Originally posted by karl k
I have no mods, original Michelin Sports:
After I experienced excactly what you did on the front tires, I increased the pressures around 9,000 miles.
F=38/40 R=35/37
Progress report:
Just changed first set of tires.
After I increased the pressure at 9,000 miles as stated earlier and repeated above, after dismal uneven tire wear because of underinflation, -- I got 24,000 miles on the original set of Michelin Pilot Sport.
Tire pressures of 33/32 are just WRONG as listed on my gas filler door.
THOSE LOW PRESSURES BENEFIT TIRE MANUFACTURERS, TIRE SHOPS AND -- SCREW SOME CONSUMERS.
My MB service shop wanted to replace my tires at 12,000 miles... - go figure.
Old 07-07-2003, 01:10 AM
hinhin7's Avatar
MB
And I was referring to the stock 17s that came with the car...
If you keep it at the suggested 32/33 listed on the fuel door panel, this is what you will get:
Under Inflated tire after 10,000 miles
Even tire wear:
Danny, I couldn't load the picture. Can you post the pictures again?
THanks,
Solihin
Old 07-07-2003, 01:50 AM
mmgrad's Avatar
THanks,
Solihin
No problem... here is a picture of the tires properly inflated.. plenty of deep grooves and very visible Nike-like swoosh marks on the side...
Old 07-07-2003, 01:52 AM
mmgrad's Avatar
and finally, here is a pic of an under-inflated tires @ the factory psi setting, notice the absense (completely worn out) of the Nike-like swoosh marks
Old 07-07-2003, 08:01 AM
  #32
steve1173's Avatar
Slk 230 & CLK500
Not withstanding the tire pressure but why does Mercedes state that the rears should be higher on the rears then the fronts. I myself am running 36 front/38 rear.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
Quick Reply: What tyre pressure?
