Turn Signal Compatibility?
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Looking for advice, I am thinking about changing my fenders to F1 fenders in which my side marker turn signals will no longer be compatible, So I have been told. I was thinking to get side mirrors with the turns singals built in, is this even possible? If not another option I might have is the after market mirrors from BMW but I dont know that will look good on my CLK. Any thoughts, ideas or suggestions?
2002 CLK 430/2002 325i
upgrade your mirrors to OEM mirrors with blinkers in them...I believe it is standard on post 2000 models. Contact Steve (MBenzNL) he can get them for you.
CLK W208
yes i just did it. the cheapest way to do it is buy the blinkers they are about $80 fo rthe pair and then buy the back piece for the mirror housing beacuase it comes painted and all you have to do is put the blinker on it and install it back on the car. the back housing is $145 for each side. and for the wiring you run the wire for the fender blinkers from inside the fender through the door harness up the door behinde the tweeter and into the mirror. it sounds compluicated but belive me it's a walk in the park.
