Need help" Wheels Hitting the Body"
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi
I just got new wheels
front 19 + 8.5
back 19 + 9.5
for my clk 320 2001 AMG kit
but I was told they are hitting (or almost) the body because they are too wide
I don't know how to solve that do I have to use spacers
I know spacers are used with AMG only
I will be greatful if you can help me
front 19 + 8.5
back 19 + 9.5
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Originally Posted by CLK A
Hi
front 19 + 8.5
back 19 + 9.5
front 19 + 8.5
back 19 + 9.5
NO different suspension I use the OEM
tires are
front 235 -35
back 265 - 30
do you think i have to use spacers 10 mm
tires are
front 235 -35
back 265 - 30
Also how wide are the tires in the front and the back 91,92,93,94,95 etc
I will try to take some Pic
the waird thing here is the wheels are not hitting top of the fenders( this is what you think) right! they are hitting the body from inside!! they are TOO WIDE that is why I am thinking spacers may help beca they will move the wheels away from the body
make sure you read at the bottom of the page and it will have a picture on the right side. hope this helps http://www.performancealloys.com/all...el_spacers.asp
2000 CLK430 Cabrio
CLK A, what is the offset of your wheels? It should be stamped on the back of your wheels. On our cars spacers reduce the offset so you can figure out how much spacer width you need based on this. I think the consensus is that the ideal offsets for 208's are 35 front and 32 or 35 rear. So if your wheels have a 45mm offset, a 10mm spacer would make it fit like a 35 offset. Make sure to get longer lug bolts if you get spacers.
