Alloys/Rims
Old Feb 14, 2006 | 04:05 PM
Froddan's Avatar
Alloys/Rims
Now I know that the proper offset for clk's is 35, but is there a chance of fitting these on a 2001 clk?
245/40/zr18 on 8J X 18 H2 ET44
Many thanks
Old Feb 14, 2006 | 06:14 PM
clkgeorge's Avatar
00 clk 320 and 3 hondas. Darn I am down to 4 cars.
The wheels will tuck in almost 1/2 inch. No problem with the fender lip, but I think you might have rubbing issues with the suspension or inside the fender.
Just get 10mm spacers and longer bolts.
Old Feb 15, 2006 | 04:46 AM
Froddan's Avatar
Thanks for your reply. 10mm spacers are all I need to get these wheels to fit then? And finally, are spacers safe to use?
Old Feb 15, 2006 | 04:56 AM
clkal's Avatar
01' CLK55
yes. hubcentric spacers are safe to use. Lorinser uses them on most applications. You can also buy them from H&R.
The spacers are NOT all you need. As CLKGEORGE stated, you will need LONGER lug bolts to accomodate the extra 10mm's.
Old Feb 15, 2006 | 05:08 AM
Froddan's Avatar
Ok, thanks to both of you. Now I can get the wheels, knowing that they'll fit on my car.
