Suspension Upgrade on a 2001 CLK320 - Questions
Old Aug 6, 2002 | 09:52 PM
Martin's Avatar
CLK320, Carrera S
Question Suspension Upgrade on a 2001 CLK320 - Questions
Here are my basic assumptions:
1. Car will be daily driver.
2. Looking for moderate improvement in handling (i.e. I am not looking to loose my teeth fillings while I drive!).
3. I don't like the amount of body roll the car has in long sweeping turns. I would characterize my driving style as moderately aggressive.
4. Keep lowering to the minimum.
5. Budget for the upgrade is $1100 including install.
6. Will probably upgrade to 17inch rims in the future.
There appears to be two ways to go.
1. Eibach springs (these will lower the car 1.2" according to the data I have been able to get) + Koni sport shocks.
2. Eibach anti-sway kit (If there are others at a similar price that you know about please comment) + Koni sport shocks.
Two basic questions:
1. Any feedback in comparing the ride quality and performance of these combos is appreciated.
2. With option 1, can I use a thicker pad to keep the lowering to a minimum?
3. Can you tell me the thickness of the stock pads on my car (front and rear) and what I could replace them with? Just a list of pad thicknesses available would be a great help.
Martin
Old Aug 8, 2002 | 06:59 PM
bmac002's Avatar
CLK 320
Mine is a 99 clk320 and I have H&R's and Bilsteins. If you like to drive aggresively and don't want to harsh a ride I think you should get the H&R's and the Koni's. I am not positive about this but I think that the Koni's set on a softer setting might smooth out some of the harder bumps in the road than the Bilsteins do. What I would like is to keep my H&R's and get some Koni's set to 2 or maybe even 1. I am sure I would feal more of the bumps than with my current setup but I dont mind them if it makes the care stick to the road! If Eibach's are going to lower your 320 1.2, the H&R's don't lower it much more than that. They may be stiffer than the Eibach's but I think the konis set to a soft setting would be a better way to even this out than using the Eibach's (someone with more knowledge please comment). I have recently gone back to my stock 16 in rims because my 17's were cheap and are all bent up and wobbly. I notice a lot more body role on the 16's than I did on the 17's. I am sure the sway bars would help (I don't have them) but when I had my 17's on and the tire pressure a little higher than reccomended there was barely any body roll. I have to get some new rims. BBS LM's would be nice but whew! expensive and 19's. I guess since its forged it won't bend as easy though.
