ecu/ chip tune?
Old Aug 7, 2002 | 09:46 AM
Pffelan's Avatar
CLK 430 Coupe + MGF + 1980 Camaro
Question ecu/ chip tune?
where is the ecu - i need the bosch number from it for superchips...
www.superchips.co.uk
they reckon should take power upto 300bhp
anyone know if this is right?
also anyone know what the clk430 coupe will run to with the 155mph limiter removed?
Old Aug 7, 2002 | 12:12 PM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
well pffelan...
when ECU's are remapped.. they certainly increase your HP and performance by a noticeable margin.
But make sure you have the right fuel grade ( octane levels ) in your country to support it. Otherwise you'll do something really bad to your engine!
cheers
Old Aug 7, 2002 | 12:15 PM
Ahmed's Avatar
Re: ecu/ chip tune?
the best way to remove your speed governor is to install a Vmax unit ( best in the market is BRABUS). Your top end should hit 270 kmh. BUT !!! remember that your instrument cluster has to have provisions for that otherwise you'll get wrong readings everywhere, you'll system will go nuts! Basically what i'm trying to say is that if u fit the brabus Vmax unit, you will also need to send your original instrument cluster to them so they would replace it with a Brabus one.
Old Aug 7, 2002 | 01:00 PM
Pffelan's Avatar
we have 98 octane across the uk so fuel is not a problem...
intrigued by the dash comments...
surely the needle just carrys on past 160?
had many cars off the clock before with no probs?
how come with merc?
Old Aug 8, 2002 | 04:58 AM
Ahmed's Avatar
dont know...
just from experience cause a friend did the same to his SL500 and had major problems with his onboard computer.
the maximum indicated speed on all mercs here ( except AMG's ) are 260 kmh. The vmax unit takes your speed past that mark so thats where the problem starts!
