Camshafts
Old May 7, 2006 | 05:11 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Camshafts
Does any one knows where can i get them from and how much will they cost? for a W208
Old May 7, 2006 | 07:23 PM
CLk430Ed's Avatar
Hey AC,
If i remember correctly Brabus has a cam kit for the 208 which is about 3k. The kit included 2 camshafts and lifters. I think the horse power increase dynoed is about 25 hp.
Ed
Old Nov 2, 2006 | 08:08 PM
OJwerks's Avatar
not stock.
well, it would be better if you were to specify what motor you have in your "w208"...
anyways, SCHRICK makes camshafts, which can be fitted with no other mods....
if you want a "kit"...then brabus offers a kit that will include the camshafts, air filters and the exhaust.
Brabus: $3400
SHRICK (cams alone): about $2200 if i remember correctly....
the cams alone will probably not be enough for you, but if you combine them with a throttle body over bore, magnecor wires, colder plugs, full exhaust system, evosport pullyes and ecu reflash and you will see a nice difference......
Old Nov 6, 2006 | 05:31 PM
Ghostrider's Avatar
01 CLK 430
MKB also has a camshaft kit, and Kleeman just has camshafts.
