them H&R springs...
1 Post
'79 300D, '85 300Dt, '99 CLK430
them H&R springs...
According to the site, the CLK55 would use different springs than the 430/320 and it lowers the car less. Does anyone know if the 55's springs are stiffer, therefore lowering the car less? Anyone know what the real difference is?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
The only reason that i could think of is that the AMG SHOCKS, not springs would be stiffer, and would thus not utilize the lowering capacity of the springs as much. Also, does the 55 squat down on its rear tires when launching? This could be another reason to keep it higher so that you dont rub on your rear wheels.
Both cars are roughly the same height after being lowered with the correct springs.
However, the 320 is lowered less (in front) than the 430 because they use the same springs yet the 320 has less front weight.
1 Post
01' CLK55
According to the site, the CLK55 would use different springs than the 430/320 and it lowers the car less. Does anyone know if the 55's springs are stiffer, therefore lowering the car less? Anyone know what the real difference is? ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
1 Post
Originally Posted by m5-mike
The CLK55 is ALREADY lower than the CLK 430 so the H&R springs won't lower as much.
Originally Posted by dimit
THe post is about Clk55 springs???
Originally Posted by clkal
you can always adjust the height even more by swapping your spring pads to dot 1 all the way around
