Moving the A/C Unit
Old Aug 8, 2006 | 12:06 PM
rubberninja's Avatar
2002 CLK55 AMG, 2005 C240 4maitc
Moving the A/C Unit
Just a quick question for all you techies... Does anyone know how easy it is to move the A/C controll unit in a w208 below the stock head unit so i can put an aftermarket headunit where th A/C Controlls used to be? I Don't want to give up my stearing wheel toggle buttons but I want an AVIC-N3...
Here's a picture of what im talking about...
Old Aug 8, 2006 | 03:00 PM
ThrillKill's Avatar
CLK/ML
It's the same size as the head unit and is also removed with keys. Pull it, then pull the storage slot and slide it in and you'll have a space for the aftermarket unit.
oops, I forgot about the toggle switches. Why don't you just put it below like I did?
Old Aug 8, 2006 | 04:35 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
TK, where did you got the carbon fiber trim from?
**** looks so hot i want it bad.
Old Aug 8, 2006 | 05:16 PM
Scottjr2005's Avatar
hell yea tk, that carbon fiber looks bad ***! Is your steering wheel also done? That would be even tighter! How much for all this?
Old Aug 8, 2006 | 05:18 PM
Bet you couldn't wait to post that pic and show that **** off tk! LOL
Old Aug 8, 2006 | 05:28 PM
CLK430girl's Avatar
2000 CLK 430
Interior of TK's ride.....
.....HOT!!! Nuff said!
So exactly what does your system "do"....just radio and cd player or much more?? Sorry for the crazy question, as most may know what the system's operations are......
Old Aug 9, 2006 | 08:57 AM
ThrillKill's Avatar
CLK/ML
Thanks I thought I posted this before (sorry for the unintentional hijack).
Did the doors too.
Cut it from a pliable sheet from a guy on ebay:
http://tinyurl.com/kblmj
Instructions at the bottom of link.
Radio, phone control, cassette, cd & navigation. The unit came out of a 2005 ML500. Thanks for the comps.
Old Aug 9, 2006 | 09:24 AM
I can't see what your refering to... put what where?
Old Aug 9, 2006 | 10:05 AM
ThrillKill's Avatar
CLK/ML
Remove the oem head unit and the storage tray then you'll have a double din slot and you won't have to mess with the climate control or toggle switches.
Old Aug 9, 2006 | 10:14 AM
jimmyp19's Avatar
2000 CLK 320
hahahha not so angry red.....funny stuff thats where i put mine too
Old Aug 9, 2006 | 10:26 AM
ThrillKill's Avatar
CLK/ML
The only thing bad (with the MC unit at least) is, when you open the unit door and you are in park, it will hit the shift knob, but you can easily move the knob out of the way plus there is no real reason to open the door anyway. Not sure how the Pioneer units open.
Old Aug 9, 2006 | 01:13 PM
Ahhhh, now i see what you were trying to say. Well the headunit i want
(AVIC-N3)
doesnt take up that much space. It sits flush in the spot previously used by the ac unit. Puls i'm leaving the stock sterio unit where it is. So to recap the ac unit is going below the stock sterio unit where the storeage unit is, and the AVIC is going where the AC unit used to be, up top. I just like the way the set up looks better that way.
Old Aug 9, 2006 | 01:36 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
You're leaving the stock radio in? Would the stock be just for looks at that point? With the new AVIC in, what purpose does the stock headunit serve?
Old Aug 9, 2006 | 01:39 PM
Whodat's Avatar
Thrill, who did that radio/headunit mod for you or did you do it yourself. If so, how easy was it?
Must be interesting having a ML on the screen pop up when the unit is on. I wonder if there's a way to change the 'desktop' image to a CLK?!
Old Aug 9, 2006 | 03:11 PM
Good question. Basicly i love my stearing wheel buttons. I Don't want to give them up, and if i want to keep using them i need to leave the Bose system as-is. Therefor i'm purchasing a Pioneer amp to go with the avic. Then i can bridge it with the bose amp and intergrade the avic. That way i can have all the audio from the avic come out on my bose speakers without changing the system. In doing this I retain use of the stearing wheel buttons. Once you change the bose system, the buttons die
Old Aug 9, 2006 | 07:40 PM
Whodat's Avatar
Oh wow. PLEASE post pics of that setup when you get it done. I'd love to see it. My question is, with the storage compartment gone, where will you put your loose change?!
Old Aug 9, 2006 | 11:45 PM
ThrillKill's Avatar
CLK/ML
Frank did a writeup:
http://www.benzworld.org/tech.html?id=66
Old Aug 10, 2006 | 09:59 AM
I Deff will... i put my change in the back seat ash tray
...Thanks for the link TK
Old Aug 10, 2006 | 12:15 PM
Motivation's Avatar
CLK 430 Coupe
Here you go..... ( excuse the blurryness, I took this with my phone )
It is a Kenwood Excelon DDX 7015 Double Din Touch Screen High def CD/DVD F.M./A.M. receiver with alot of other stuff too ( even Navi if you purchase the extra piece) It required NO modification, they pulled out the factory unit and shaved down the plastic piece and Voila!.....
Old Aug 10, 2006 | 12:51 PM
jimmyp19's Avatar
2000 CLK 320
i love the CLK astray door mod...very classy....
Old Aug 10, 2006 | 02:20 PM
ThrillKill's Avatar
CLK/ML
You are evirrrrl.
Old Aug 10, 2006 | 04:34 PM
Motivation's Avatar
CLK 430 Coupe
Yea, your opinion counts. This comming from someone who spent more on their rims and body kit than their V6
Old Aug 11, 2006 | 03:16 AM
blisscafe's Avatar
this is what i did
i got tired of the dvd blocking the ac controls it was a simple swapping of places had to trim the storage unit to fit the space the ac controls came from
for all you people who want to remove your headunit or your ac controls just get 2 big sized hair pins. peel off the rubber nubbies at the ends then slide them into eachside of the units and pull outwards. used to install car stereos learned this trick
