Rear side interior trim removal?
Old Aug 16, 2006 | 10:27 PM
ytri's Avatar
Hi guys, I've searched without coming up with much. Just want to know how do you remove the side trims in the back? I have the worst rattle coming from the passenger side, seems to sound like it has something to do with the front seat belts? Any help much appreciated
Old Aug 17, 2006 | 11:49 AM
bnz.'s Avatar
02CLK320
That's not easy, my friend. Before removing a side trim, you would need to remove basically everything else around it: door sill, rear seats completely, etc.
The trim itself is holding in place on clips on top, screws on bottom, and there is one little 'stick' part of the pannel on the pillar that goes inside of the side pannel (that you are removing) and holds them together.
And it will be much harder to put it all back.
