Starting problem, FINALLY SOLVED!!!!!!!
So i've had a problem starting my car for a while, and I found the cure...I had it hooked up to a scanner several times, including once at Mercedes, and even they were perplexed. Checked fuel pressure, plugs, wires, starter, battery, fuel filter, replaced CPS, etc... nothing. However, when I tried switching the 12v relay that is under the hood, with the fuel pump relay, bam, started right up every time. And, I didn't have to buy a new relay to find out that's the problem. When I switched the relay the car started fine, but then I got the ESP, BAS, ABS malfunction. So I bought a new relay, so they were both good, and that problem was gone. So a word to the wise, before going through hell as I did, first just swap those two relays and see if the problem is gone, it's free and takes 30 seconds. Also swap them if you are getting the BAS, ESP, ABS malfunction just in case it's not the break switch.
