Nitrogen filled tyres vs. air filled
2002 CLK320, 2006 4.8is X5
Just had my tyres filled with nitrogen. Does it really make a difference? I haven't felt any changes, but I'll be checking mileage these days.
Any thoughts?
Any thoughts?
W211 / E280
If I remember correctly they did this experiment on Mythbusters on Discovery but for the life of me cannot remember the outcome on thier investigation.
'00 CLK430 & '08 Lexus RX 350
The difference being.....
Nitrogen has a more stable temp than Oxygen therefore there is less variance especially at higher speeds or in extreme climates therefore less variance in tire pressure. Oygen also holds moisture which Nitrogen does not so if you have crome rims this is a plus as moisture in your tires can lead to pitting in the crome.
So, for a few extra bucks you have more temp stable tires which can lead to improved tire life and mileage and save you from pitting your chromed rims!
2006 Lexus GS300, 2007 Lexus GS350
granted, I didn't do as well as others in Physics 101.
here was my line of thinking:
oxygen/moisture + heat = expand. expand = higher temperature = higher
pressure = less cushion.
conversely, nitrogen, being more stable under temperature and moisture variations
will hold the initial/charged pressure. thus, you can set pressure to comfort
mode and it will vary less.
truth be told, i slept during class.....
If you check the air pressure when the tire is cold, it will be less than if you check it after riding around. Heat and friction causes the molecules to expand. More air prssure, more cushion. That's comparing air to nitrogen.
Comparing air to air is different. More to your point. 40 lbs of air will feel harder than 32 lbs of air because the sidewall is stiffer.
Hopefully some science expert will chime in and set us both straight.
well, I'm not a scientist (and I don't play one on TV either
) but, having worked in aviation for a couple of decades, where ALL tire get only nitrogen, and tire speeds up to 225mph, both of you have a line on it...yes, the expansion of the gases due to heat will increase pressure, the 2 gases have about the same coef.of expansion, but the water vapor in 'air' expands more, therefore 'air' will expand (and inversely - contract) more then pure nitrogen. The cushion effect is just the difference between cold and warm pressures (2 or 3 psi nitrogen / 4-8psi air). its the pressure that softens or stiffens the ride, the nitrogen is just a more stable media, so you shouldn't need to tweak it as often...expanding gases in a fixed container (tire) won't give a softer ride, but will bulge the center tread and wear out the tire in the center, just has less pressure puts the onus on the sidewall/outer treads.. the trick is to get the happy middle-ground..
the moisture on the chrome wheel is a good point, though..
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Nitrogen has three major benefits: 1) longer life of tires (because oxygen and ozone in air breaks down rubber) and wheels and valves (because of lack of water vapor); 2) slower pressure leakdown (smaller oxygen molecules escape rubber more quickly) and 3) longer tire life because they run cooler.
All three effects are small.
