Please Help With Wiring!!
This pump circulates water into the heater core. My two wires came off. Can someone PLEASE go look at their CLK55, CLK430, CLK320 99-02 and tell me what wire is on the bottom.
The pump outlet faces the car firewall.
You will see two wires that feed the pump. If I get them backwards the pump flows backwards!!!
One wire is Red with Yellow strip. The other wire is Brown with Green strip.
They will be easily to see if you open the hood and look with a flashlight just to the left of the engine!!
Thanks.
Again the connector to the pump is at the back of the pump. Easy to see.
Greg
