H&R Spacers
H&R Spacers
Do the H&R spacers (10mm) for $95 come with any bolts? I'm not sure as to how the spacer works. Does it come with bolts to mount the spacer and then you use separate bolts for the wheels? Thanks!
H&R spacers don't come with bolts.
Eibach spacers, do come with bolts (that's why they cost more).
The bolts are longer versions of your current bolts to accommodate for your use of a spacer. For example, if your stock bolts are 25mm long and you add a 10mm spacer, you would then need a 35mm bolt so it would be able to reach through the spacer and meet the hub.
