Looking to buy a 2001 clk 430
Old Apr 2, 2007 | 07:30 AM
Tedz C's Avatar
I'm looking to buy a 2001 CLK 430 w Nav system and it has 81k miles. What should I look for and can you activate the phone
Old Apr 2, 2007 | 08:21 AM
gregory13lil's Avatar
2000 CLK430
Look for Bad motor mounts, burned out instrument cluster pixels, rear differential leaks, loose steering, and then of course the normal stuff like driving smooth, good sounding engine (not rough), good tires and good paint, and just an overall good condition to your satisfaction and taste. I would definitely do a longer than normal test drive over rough and normal roads and freeway driving over 60 to ensure there is no shaking at all, and then hit the brakes kinda hard and it should be smooth.
Put the car on a lift and check the car for any leaks...this can be quite expensive to fix if you cant do it yourself. For example, the rear differential leak repair is around 800 bucks!!
Hope this helps!!
Greg
