Gas Cap not fitting
Old Apr 22, 2007 | 02:04 PM
s.f.clk02's Avatar
CLK320 2002
Gas Cap not fitting
wusup everybody after filling up gas i tried closing my gas cap and for some reason it will not tighten actually it seems like it doesnt even fit anymore anybody ever had this happen before? I searched and couldn't find anything. thanks
Old Apr 22, 2007 | 02:53 PM
jtbeche's Avatar
02 E55; 99 CLK430 (Sold)
I had something like that happen. What it ended up being is the black plastic ring around the outside had not twisted correctly and was stopping me from putting the cap on properly. Mess with that and see if it helps.
Old Apr 22, 2007 | 05:53 PM
s.f.clk02's Avatar
CLK320 2002
thanks for the help i got it to fit. i just had to mess around with it pretty hard. anybody know how to get rid of the check engine light?
Old Apr 23, 2007 | 05:14 PM
jtbeche's Avatar
More than likely.....just drive it. I think it's supposed to turn off after a couple of trips.
Old May 21, 2007 | 07:21 PM
rodwilk's Avatar
98 CLK 320 03 ML500 04 SL 500
black CLK
I don't know about the gas cap but that BLACK is BANGIN. It looks so deep and rich. Good job
Old May 21, 2007 | 07:43 PM
BilOutkast's Avatar
This has happend to me also, you need to line up those two notches in the proper section, press down firmly since the springs pretty strong and try turning it. Use a flathead screw driver, pliers, etc.
Old May 21, 2007 | 07:44 PM
BilOutkast's Avatar
edit: n/m I see that you fixed it =)
Old Feb 28, 2008 | 12:27 PM
Roehl's Avatar
2004 MB E-500 & 2000 Honda Accord Coupe
It just happen to me yesterday. I took it out and good thing I have an old t-shirt in the trunk and plug it in replace of the gas cap to prevent check engine light. I fix the gas cap at work and put it back in.
So, when you take out the gas cap you have to twist it all the way to prevent this from happening.
Old Feb 28, 2008 | 03:43 PM
Mr Pie's Avatar
CLK320 / E500
Seriously? a t-shirt?
Old Feb 28, 2008 | 04:08 PM
The Jury's Avatar
2002 c240
In Alabama that IS a gas cap.
