Dead battery - locked trunk
00 CLK430
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
dont use it to start the car...just plug it into your cig lighter when your battery is dead, and it will give enough juice to pop the trunk
L___________ from the side, for the trunk the L is upside down. Hard to explain clearly but it kind of looks like the trunk takes it upside down. After using the lubricant I inserted the key, back and forth, jiggling, pushing, etc. I couldn't believe it made it all the way in. Remember you need to get it so the key is all the way in before turning and pushing. Once I got it in I used a pair of pliers to turn the key slighting left, slighting right, back and forth, being very careful so as to not break off the key. Didn't think I was getting anywhere but all of a sudden it turned. To open is like a 30-45 turn to the left and then you push the button and trunk opens. I have been having a bunch of electrical issues that may or may not be related but after I got the trunk open using the key I can now open the trunk using the cabin trunk switch and the key fob neither of which worked before.
