Seats Again
Old Jun 17, 2007 | 12:29 AM
s.f.clk02's Avatar
CLK320 2002
Unhappy Seats Again
Okay wusup everybody ive changed my fuses at least a good 10 times since ive had my car but this time its not the fuse or i think. the passenger side seat is stuck all the way up wont move forward or backwards. i was cleaning my car and moved it all the way forward then i was done and now it will not go backwards. it will move up down but not backwards. anybody got any solutions i really dont want to take it to the stealership.
Old Jun 18, 2007 | 12:09 AM
viguera's Avatar
CLK 320
It could be the motor... mine is acting up and there are a couple of threads of diff people with the same issue. At least yours is the passenger side... mine (and others) are the driver side motor...
Old Jun 18, 2007 | 12:48 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
It definitely the motor if you pull back the switch, you hear click but the motor doesn’t move. I got this problem before.
For now just use a small screw driver, gentle knock on the motor under seat try to pull the button you will probably have chance to pull it back the old way. But you need to change the motor soon.
Good luck with that
Old Aug 7, 2007 | 11:47 AM
babyjrluv's Avatar
2001 clk55 amg
s.f.clk02 Were you able to resolve the issue with the seat? If so what did you do. I'm having the same freaking problems.
Old Aug 7, 2007 | 12:36 PM
s.f.clk02's Avatar
CLK320 2002
naw no luck with the dam seat. i think it is the switch because sometimes it works and most of the time doesnt.
Old Aug 7, 2007 | 06:00 PM
viguera's Avatar
CLK 320
It could be... in my case it was the motor and it would never work, ever. But you could hear it "clicking" when you pressed the button.
It's weird that the switch would go bad though... does it work up/down? Because mine would move up/down, and it would "click" when going back/forward but the seat wouldn't move.
Haven't had any problems since I replaced the motor though.
Old May 19, 2009 | 11:34 PM
poptopclk's Avatar
2017 X166 GLS550 & (R230) SL550 2007 & 2012 S550
how do you know if it is the ECU or the motor?
Old May 19, 2009 | 11:39 PM
sfclk's Avatar
1999 CLK320
Have to tried unplugging the switch and plugging it back in?
Old May 20, 2009 | 03:08 PM
sonnyhoang's Avatar
w208 CLK430, w212 E350, w221 S550
do the chairs work for a while when u changed your fuses?
