Kreaky Kmac Kure
Kreaky Kmac Kure
There is a permanent fix to KMAC creaks. A grease fitting drilled & tapped into/thru its race, using a synthetic bearing lube will even add an extra level of smoothness and precision. Not to mention adding extra life.
Very good idea to fix the problem and definitely not just a bandaid solution. Thanks for the tip! I wish they would starting making the bushings from ploygraphite.
