No Engine Start at 90 degrees C
Old Aug 9, 2007 | 01:04 PM
rubixcube007's Avatar
My 99 CLK 430 heats up to about 90 degrees C then if turned off will not start again. Starter turns but no startup. I can run the heater on high for a few min to get the temp back down to ~85 and then the car will start. If i let the car run to about 95 degrees the auxillary fans kick on and only take it back down to ~90 then shut off. Anyone know what might be the problem?
Old Aug 10, 2007 | 04:42 PM
928Benz's Avatar
1999 E300 TDI, 2000 CLK430, 2000 E320, 2003 S55, 2005 SL500, 2011 ML350
I had a similar problem not too long ago. If you allow the car to cool down, it will eventually start. Sounds like the CPS (crankshaft position sensor) is gone. If it is, it's relatively inexpensive. I think like $119 fo the part. Take less than an hour to install. Hope this helps.
00 CLK 430
