HELP...VERY wierd AC problem!!
Old Aug 23, 2007 | 10:02 PM
JamesYang's Avatar
00' CLK320
I am facing a very wierd AC problem right now, it's so wierd that My AC just wouldn't stop blowing even when I pull the keys out. and i leave the car for 20min and it still blowing.(I didn't have the REST botton on)
Anyone know what's the problem??
it's a 2000 CLK320
Old Aug 23, 2007 | 11:07 PM
JamesYang's Avatar
00' CLK320
The only way to stop it is that i have to disconnect the battery of the car.
Please help thx..!!
Old Aug 23, 2007 | 11:40 PM
W2O8TC's Avatar
W208
I had an exact problem before. Sounds like your current regulator's shot.
It will cost you $199 for a new regulator. I ended up paying $419 including the labor. Until you get it fixed, take the fuse out of the fuse box located under the hood.
Old Aug 24, 2007 | 03:00 AM
JamesYang's Avatar
00' CLK320
Can u tell me where exactly is the fuse box located..??
Cuz i am not too good with this kind of things..
Old Aug 29, 2007 | 06:04 PM
derek m's Avatar
02 CLK55, 07 E92 335 ProCede
It's in the top right under the hood. The manual I believe will tell you where the fuse box is as well. In the fuse box, on the underside of the cover, it will tell you which fuse corresponds to the fuse you are lookin for.
Old Aug 29, 2007 | 08:49 PM
TresX's Avatar
Your blower motor regulator is located under the dash by the passenger footwell. Take the plastic cover off (held by 3 screws I believe and you will see it) When the drains by your winshield wiper cowls get clogged by debris (leaves and stuff) it will direct water towards your blower and you may even experience a wet passenger floormat. Check to see if you have any corosion that is causing some sort of short before you fork over $$$ for a new one. Even if you have to, it is a pretty simple swap.
