wat should my clk 430 temp. be at???!?!?!
clk 430
i was wondering to all the fellow benz owners im not to shure but my clk 430 is kinda old and wat not but i was wondering wat the temp. of the car be at? the needle in the car is lik close to 90 degrees is that correct? if not any way i can fix that? thanks guys!
SL55, C63
90 degrees Celcius sounds about right.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
a way to check actual eng temp is to hold the rest button then go up to number 5? i believe by hitting the auto button 5 times and it tells u...i tihnk its number 5
