Wheel dimensions
Old Nov 4, 2002 | 04:27 PM
Janus's Avatar
MB CLK 230 K -00
Wheel dimensions
I have seen alot of people have for ex: 225x40x18 on the front wheels and 245x35x18 on their back wheels. I wonder why ? The diameter of the tire will be different from eachother.
I´m thinking of buying Carlsson 18" to my CLK and dont know exactly which tires to buy. If I put on tires with another diameter the the original 215x55x16, do I have to adjust the (dont know the english word) wheel settings. So I dont wear out the tires on the inside or the outside.. Hope you understand....
How wide tires can I use without any major adjustments. Thinking of the fenders ??
Sorry for my poor english...
/Janus
Old Nov 4, 2002 | 05:54 PM
LowRydeR's Avatar
225/40/18F 255/35/18R will not rub against your fender/car with right suspension setup, if you use different spring pads or cut springs, they'll definately rub and wear out unevenly real fast.
-Bruce
Old Nov 4, 2002 | 06:26 PM
nickv's Avatar
Used to be a CLK430
You can also use this setup with the factory suspension although your call will sit a bit higher due to the increased overall diameter of the wheel.
Old Nov 4, 2002 | 06:34 PM
LowRydeR's Avatar
Yeah, but I assumed that he's going to lower the car with aftermarket springs.
-Bruce
Old Nov 6, 2002 | 10:10 AM
BANSASN's Avatar
CLS 500
225/40/18 Front, 265/35/18 Rear. NO rub and with stock spring.
BANSASN
Old Nov 6, 2002 | 02:56 PM
Janus's Avatar
MB CLK 230 K -00
Tnx
It´s an avantgarde.. Isn´t avantgardes lower then Elegance ??
Do you recommend to lower it even more ?? The roads here in the north of Sweden aren´t the best. I don´t what it to be to bumpy so I have to drive like my grandmother... If you know what I mean..
/Janus
