Crank Position Sensor vs. Crank Reference Sensor
Old Nov 5, 2007 | 11:49 AM
waterford5301's Avatar
'02 CLK55 and Hummer H2
What's the difference, if any between crankshaft position sensor (003-153-28-28) or (F6010-1400980) found on sites between $80 and $120.....and the Mercedes Crank Reference Sensor found on sites such as onlinewholealeparts dot com for around $40? The pictures of the items look the same. I found other site with parts in the $40 range for the crank reference sensor - even e-bay has it
http://cgi.ebay.com/ebaymotors/98-07...spagenameZWD1V
Does anyone know if these are the same parts or what the difference is??
Attached Thumbnails Crank Position Sensor vs. Crank Reference Sensor-f6010140098hel-1-.jpeg   Crank Position Sensor vs. Crank Reference Sensor-yhst-75109527211115_1972_1087391-1-.jpg
Old Nov 5, 2007 | 03:50 PM
gregory13lil's Avatar
2000 CLK430
Those 2 parts look like the CPS (Crankshaft Position Sensor)..theyre just calling them different names.
Old Nov 5, 2007 | 04:54 PM
It's funny that there is more than a $60 difference in the 2 parts. I found this on another forum..(in an ML section)
In terms of resistance..with a meter or something...
I have it pulled out.
And if there are any Super Knowledgables out there. Why are two CPS's listed for the ML320- one (aka) Reference Sensor is interlock single and one is interlock double .
RE:
voltage (alternating current):
>2.0 ~ volts cranking
>5.0 ~ volts idle speed
resistance at 20 degrees centigrade:
bosch: 925-1255 ohm
AB electronics: 610-750 ohm
http://www.mercedesforum.com/Is_Ther.../m_7110/tm.htm
I guess the Bosch sensor is better?
Old Nov 13, 2007 | 11:09 AM
Quick Update..
I ended up purchasing this part on e-bay:
http://cgi.ebay.com/ebaymotors/ws/eB...m=260177188805
Installed it over the weekend - The car immediately started and is running much better. The rough idle is gone and it has started every time.
Thanks to everyone out there who posted How-To's. I never could have done this without you guys!
