OEM Amp Question?
Old Nov 25, 2007 | 10:09 PM
falls profet's Avatar
OEM Amp Question?
Before I rip this stock amp out, does anyone know if the factory Bose amp
has a gain control on it??
Old Nov 25, 2007 | 10:20 PM
OPALW208's Avatar
SL55, C63
from what I remember, the factory bose amp does NOT have a gain control.
Old Nov 26, 2007 | 11:18 AM
Damn, really? I was hoping it did, and not for reasons of it being insufficient. I
put in an Alpine deck and now my sub has a hard time keeping up with the
factory highs and mids at most volume settings and I need to turn it down. I
have to say, I am really impressed with how they really came alive with an
aftermarket deck. They're loud and clear and sound completely different from
the factory head unit.
Old Nov 26, 2007 | 01:53 PM
The Jury's Avatar
2002 c240
Why would you try and adjust from the MID amp if the sub is the issue?
Old Nov 26, 2007 | 03:17 PM
OPALW208's Avatar
SL55, C63
+1
Old Nov 26, 2007 | 04:31 PM
Well for starters, my bass amp is already at a little past half gain. You never
want to run any amp full gain unless your in a competition or for extremely
short periods of time. You make your amp work too hard and can fry the
mosfets/board, etc. much faster if you run it full daily,especially if your
running it at 1 ohm like I am. You put much more strain on your entire
electrical system the lower the impedence and the resistance is that much
greater between your battery/power source and your bass amp. So, you
compensate, like you all probably know, between your deck, highs/mids amp
and bass amp all together.
Even at low volumes the highs are much louder than normal and only get
louder as the volume increases. My treble on the deck is set all the way
down too. I guess the added output power from the deck makes that much of
a difference which is why I should have got a pre-amp only deck instead.
