Strering wheel shaking + engine mounts
Old Dec 9, 2007 | 11:53 AM
Focus on this 1's Avatar
Clk 55 04
I know my left engine mount has to be replaced is it possible that it causes my strering wheel to shake at about 50-60 mph????
Old Dec 9, 2007 | 06:50 PM
Jessica90's Avatar
BMW
Motor mounts do not cause the steering wheel to shake.
I had the same problem in my 7 series bmw.
There can be numerous things that cause your steering wheel to shake at those speeds.
You might have warped rotors and if your rotors are fairly new, the lug nuts might have been over-torqued which would usually cause warped rotors.
Check your brake calipers.
Maybe you have loose or worn out wheel bearings.
Check your front bushings (control arm, etc...)
If the rotors and associated brake parts are ok, go to the suspension for the answer (F traction bushing, idler arms, tie rod ends etc...)
Start with the basics; like bent wheels, balancing, wheel to hub fitment.
Hope this helps.
Old Dec 9, 2007 | 07:25 PM
John 99CLK430's Avatar
1999 CLK430 (sold) 03 CL55
Damn Jessica....
Old Dec 9, 2007 | 10:00 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Originally Posted by John 99CLK430
Damn Jessica....
For real she ,got all the bases cover.
Old Dec 18, 2007 | 10:28 PM
Jessica90's Avatar
BMW
Haha, thanks guys.
Just sharing the knowledge I gathered when I had this issue.
