Aftermarket Headunit Question?
2007 bmw 650ci / 2007 Infiniti g35x / 2001 clk430 conv
and pac but i dont know the # of the pac they used i jsut took my car there and told them what i wanted it but you can call them and ask them for sure
2000 ML430
In fact, I *KNOW* that I ejected the magazine that was in there before I test drove the car.... so.. no idea what changed to make the head unit stop working. Fuse makes the most sense to me but dangit if I can find a blown or missing fuse...
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
So, for a 2002 CLK 55 are these the parts that are needed:
I'm still confused as to which wiring harness to use. Can someone tell me which one? Does the Factory Bose Amp have to be bypassed (meaning harness #2 below)? I'm looking for the least amount of work/re-wiring as possible. Also which two wires on the harness needs to be modified and modified as in ???
Help.
"Amp Integration plug - Mercedes C230 C240 C320*Fits models w/Factory amp. Does Not work if you are planing to remove the factory amp and not use it."
![](http://i22.ebayimg.com/03/i/08/6d/7b/ce_2.JPG)
"If you are installing an aftermarket radio in your car you need this harness."
![](http://i20.ebayimg.com/03/i/08/67/d3/4e_2.JPG)
Mercedes C230 C240 C320 Radio Mounting Install Dash Kit (no clk listed, cut out middle plastic piece):
![](http://i13.ebayimg.com/01/i/08/54/29/f7_2.JPG)
Import to Domestic Antenna Adapter:
Help.
