Hey guys!
Old Jan 7, 2008 | 10:56 PM
riannausa's Avatar
2001 CLK430 & 2007 350Z
Exclamation Hey guys!
I need HELP!! i think i need to replace my fuel filter already because my car is starting to shake and i mean shake the whole car! is there a manual for changing the fuel filter on this site?
Old Jan 7, 2008 | 11:31 PM
wnycec's Avatar
2000 CLK 430
Sticky: How to Thread at the top of the 208 forum as you enter
Old Jan 8, 2008 | 01:17 AM
BrisCLK's Avatar
CLK230 Kompressor Elegance
Mind you, could also be that one of your cylinders' spark plugs isn't firing. Check that you have a spark at each plug: one-by-one pull the lead off the plug and hold near the plug. You should see/hear a sprk jump accross the gap). If you experience a zap yourself in the process, your leads are too dirty and are earthing out against the engine block (or your fingers) via the filth (painfull way to discover that -moral of the story: keep your engine bay clean!)
Old Jan 9, 2008 | 11:42 AM
riannausa's Avatar
ok
that will be my next project if the filter does not work. but is there another way that is not painful??? by the way they said that its a pain to remove the plugs on your own! what tools do i need to do that??
Old Jan 9, 2008 | 12:57 PM
blackbenzz's Avatar
haters crazy
You sure its not the engine mounts? Plugs are a PITA
Old Jan 9, 2008 | 04:16 PM
CARLSS0N's Avatar
w208
use this if you are too lazy to remove the spark plug and save yourself from troubles
http://www.tooltopia.com/index.asp?P...OD&ProdID=5090
Old Jan 9, 2008 | 04:27 PM
blackbenzz's Avatar
haters crazy
Does that thing really work?
