Help!! Codes P0171 And P0173 Pulled
Old Jan 8, 2008 | 10:13 AM
1998CLK320's Avatar
1998 CLK 320
My Cel Has Been Going On And Off For Awhile Now
And I Just Got The Codes Pulled Today
I Read That It Could Be My O2 Sensor
A Fuel Trim Malfunction?
But Ultimately A Maf Sensor.
How Do You Put In The 02 Sensor
The Maf Takes Seconds To Put In But The 02 Sensor????
Old Jan 12, 2008 | 06:42 PM
High Technology's Avatar
2020 GLC300 & 2009 SL550 (previously had 1999 CLK / 2006 E500 / 2011 GL450)
Start by cleaning your MAF (Pep Boys has MAF cleaner). Do it a couple of times, then reinstall. If that doesn't work, then I think the MAF will need to be replaced. These are both fuel trim errors, which indicate the MAF.
I think you would have gotten another code if the O2 sensors were bad (I did - P0140-something if I recall). Regarding replacing O2 sensors, supposedly they screw in like spark plugs (although I haven't tried myself; I paid the dealer an hour of labor to do it since I was too lazy to find the part elsewhere).
If you can't reset the codes with a code reader that you have on hand, disconnect the battery for a minute. Note that either way it will likely take a couple of days to know if the CEL will turn back on.
Old Jan 13, 2008 | 01:12 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
could also be some kind of vacuum leak...check all the clamps around your air box and all other piping to your engine...then get the code erased with OBDII and see if it comes back up...
Old Jan 13, 2008 | 01:44 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Do you mean Oxygen sensors? they're located under the car, before and after the cats is where you find this oxygen sensors and our cars have 4 of them.
Old Jan 13, 2008 | 02:07 PM
John 99CLK430's Avatar
1999 CLK430 (sold) 03 CL55
4??? Holy chit, serious? I'm going to look at it later, I thought it had like 1 or 2!
