another w208 tranny problem AGAIN
2 days later the same thing occuried, back 2 da shop, the guy at the shop said that my 5th gear is shot so he said he rigged it so you can drive it but you have too drive it in gear 4 but i cant send it into 5th gear.
So that work ok for a couple of weeks now the car wont hold any power, i mean i have too jump it too start it it drives this started one evening i was washing it and when i finished washing it the bas light came on , now when i turn the car off it wont turn over unless i jump start it. and the radio code is needed to turn the radio on
any help out there
i have a great tech in L.A.
Good Battert Voltage 13.16v
Measured: 662 Cca
Rated: 825cca
Temperature: 34degrees F
So Could This Still Be From A Collasped Battery Or Is It The Bas Light
