Do you need to change shocks when lowering?
Old Feb 6, 2008 | 08:55 AM
Unil's Avatar
CLK 230K Avantgarde (Manual)
I am in the middle of choosing the right set suspension kit for my w208 avantgarde 230k.
Will i get away with just purchasing the springs, as i am aware that Avantgarde's already sit 10mm lower than elegance.
If i was to lower the car 35mm, is it detrimental to the shocks if they are not changed and will this affect the ride in a big way?
Old Feb 8, 2008 | 05:29 PM
Ghostrider's Avatar
01 CLK 430
The OEM shocks will go out faster with a lowered suspension. Depending on the conditon of the shocks you could get away with changing them out in a year or so.
Please note that the shock actually control the ride of the car, so it will be a little bouncy aftermarket springs and OEM shocks.
Old Feb 8, 2008 | 05:34 PM
150shot's Avatar
08 CLS63, Honda Accord, 04 911
I have always been told YES. Do it right. It isnt a honda civic youre lowering...I thougt the same but decided against and will go with the whole package.
Old Feb 10, 2008 | 11:24 PM
bankerkys's Avatar
2010 C350; 2022 MB GLE350
Re:
That will be a pretty good drop, so I would go ahead and change the dampers. You can get away without changing them now if money is an issue, but you will probably be unhappy with the car's ride. You can get a set of Bilsteins pretty cheap on E-Bay. I would just do the entire job at once. Good luck with it.
